RT4WD 30+ MPH Gear whine
Searched the site but didn't really find any info on my issue, I have a 1991 RT4WD that when I get above 30 MPH I get a high gear type whine, ive already flushed gear oil in both rear diff and transmission and its really hard to pinoint the whine. looking here to see if anyone's had a similar issue before I throw parts at it. Thank you for your help.
tried both in and out of 4WD. also doesn't do it right away takes about 10 miles of driving.
It would take about 5-10 miles to start making noise as well.
This would at least rule something out.
Your issue sounded just like what mine was doing.
Hope this helps!
Just blast some WD-40 down in the cable's housing. also lube the cluster's little "wheel assembly".
This happen to my '87 RT wagon last year.. I chased the problem for about a week.
does it squeak or howl no matter which forward gear you are in?
left side transfer cover(next to where the rear center axle attaches to the tranny.A cover w/ 5 bolts) to check the brg & Thrust shim adjustment.
Also open & check the Driven gear assembly (A heavy piece that concise center axle flange ,6 bolt cvr,brg,& transfer gear)where the rear center axle attaches to the tranny.) to check the brg & backlash.
This could be a early sign of the brg going bad.My brg exploded.I couldn't even find the brg except for the outer brg. race.The transfer area seems to be a weak point for the 4WD Wgn.I've seen a many 4WD trannies going bad this way.
This may help ?
