which intake type for best MPGs
                    i have been messing around with a few intake parts before but havent really been able to make a clear analysis of what the better intake type is for best MPGs as my car was always getting modified with like headers, wider wheels, lowering etc..
basically i would like to know which intake type is the best, for example:
-complete stock box
-stock flat filter with no box
-performance flat filter
-cone filter
-mushroom filter
the best MPGs i got were with the cone filter but that was before ANY modifications at all... ebay and such claim that there CAI cone filter systems get you better gas mileage from more free flowing air, but i also heard that freer flowing air reduces MPGs.. so what is true?
-complete stock box
-cone filter
-mushroom filter
A good compromise would be a 2.5" intake tube, 2.5" inlet pod filter and a cold air box with cold air ducting. Too many people go for the 3" intakes and you tend to lose alot of throttle response and economy because of it.
Like what was already said, your driving style will BY FAR have the biggest influence over your MPG.
i've never had any idle issues or blurps with a CAI... anywho.
I had in in all my vehicles. I even have it in My SV1K along with some other mods...
As for MPG, I haven't noticed any increase/decrease from stock air box.
What I have is a stocck snout that connects to intake and an elbow form an E350 7.3DTI intercooler pipe with a K&N cone filter at the end (behind battery).
It sounds like a WRX at full throttle.
I've been getting stron 28-29 MPG with my 4WD waggy.
I am planning to cut a hole underneath the filter and fit it inside the fender away from heat of engine compatment. I have 2 or 3 spare elbos from E350 7.3 DTI
MPG is affected by two factors your right foot and where you live(terrain).
Hilly areas, urban invironment will yield lower MPG, open roads, country side will do opposite!
As for CAI it has to be combined with adequate exhaust system to perform as designed. Never forget removing exhaust back pressure lower TQ output...and low to mid range performance...
Breathing(intake air) and exhaling(expeling gases) is everything even for a car
I think it is not worth to alter stock system unless perfomance mods are in order.
I did it because I had CAI set-up from a previous car ... :roll:
Cheres!
