DOHC ZC 1988 clutch question
Hey guys, Im currently looking for a clutch for my 88 civic wagon with a ZC swap. Its a 21 spine but i want to know what size clutch do i need? 190 or 200mm? I have read both and want to be sure.
Thanks
Thanks
1989 CRX/Civic/Shuttle 20 spline input shaft 200mm flywheel
1990-91 CRX/Civic/Shuttle 20 spline input shaft 212mm flywheel
200mm with a 21 spline hub is oddball. You sure of those numbers?
Probably stupid questions but i do really appreciate everyones helps
I'm confused: do you intend to buy an aftermarket flywheel, or use one that you have? Does the ZC have a flywheel on it?
If you're trying to mail-order the whole setup, then the 190mm set for an'88 would be the simplest.
Try that link, don't know if it will work, I'm not too computer savvy. If not, search for ACT clutch 3000103. The part I want you to see is the applications. The same disc fits 84-87 Prelude 2.0 and 86-89 Accord. It's a 212 mm disc with a 21 spline hub. I'm not endorsing this particular disc, it's pricey in my opinion, but this is how I put the big clutch in Fool's Gold with an 88 transmission.
The ZC still has a clutch and flywheel attached to it but i was preferably after a new flywheel as well. Just bought the clutch and will put an order in for the flywheel tomorrow.
CHEEEEEEEEEEEEEEEEEEEEEEEEEEERS
