HELP!! Fuel pump??
So I was driving home late last night the 1991 rt4wd was driving normal and all of a sudden the rpms dropped and the car died... power works... nothing is leaking nothing smells burning... oil is band new and a half tank of gas... it turns over but that's all no knocks or ticks just went out... fuel pump?? any suggestions... if so what fuel pumps fit on these is it interchangeable between crx out other cars??
i would also check for SPARK. these cars are notorious for faulty distributors. if you arent getting spark, pop off the distributor cap and take a look inside to see that the rotor is still where it should be. sometimes the rotor screw comes loose and falls out. if its all intact you may have a faulty distributor.
easy stuff first!
to answer your last questions, any 4th gen Civic fuel pump will work. probably even some Integra ones, etc..
I'm no pro but this doesn't seem right haha
that hole in the top had a piece sticking out and I somehow lost it and that part whrre the blade was had a screw that fell and cant find it could the screw that was not connected cause it?? and is the piece essential
