Measurements of a 4WD front diff?
Does anyone have a 4WD front diff out of the box that they would please be able to do some measurements of for me?
I've got a spare box, but don't want to rip it down at present as I've got no where to store/do it whilst it's in pieces.
Can anyone please help out ?
I am aware of the 12 verses 10 bolt issue.
I want to know how far out the ring gear flange is from the ZC diff.
Failing that, there are other options potentially available to me.
Due to the link up between Honda/Rover in the 80's & 90's with gearboxes/cars that the US didn't get.
So likely haven't been able to consider/dismiss as possible solutions.
Ive used a dual cam zc in the rear with minor modification
Hiya,
Did you get a chance to take a look please ?
I've grabed a scrap Y1 and Y21 diff from a mate.
I have a spare L3 DOHC ZC box in my garage to strip down now too.
All for comparisions.
Sorry.
Bearing mount diameter - 40mm
Bearing OD - 80mm
Bolt hole cross distance - 122mm
Overall length - 130mm
Speedogear OD - 93mm
I did not measure the OD of the larger FD gear.
There are 12 bolts.
I didn't think about measuring the offset. I'll try to do that next time I'm at the shop.
I'll measure up what I've got and add to the thread.
