Converting 2wd to awd (4wd)
                    I've found various answers to this question here and doing google searches. It seems everyone agrees it's doable but my question is, are all the mounts and things there already? It's raining like crazy here and I just got done with my epic trip picking up both these cars to go look. I'll get them both on my lift at work at some point and verify, but I was hoping someone here has confirmed knowledge.
Basically here's what i'm looking at doing. My plan for the RT was to go K for sure though i'm also toying with the idea of doing a J swap now. I'm 100% committed to keep awd with what ever option I choose. So with that, the drive train is going to have to be modified or custom built anyway... and that got me thinking.. Why not build two at the same time? I was just questioning if the 2wd could take the rt swap? Like if someone had a parts car they wanted to swap over into their daily. If it can take the conversion with out hacking it all up, I think I may turn it into an AWD then and just sell it here locally to make up some/all of the costs on both cars.
Any thoughts?
Any thoughts?
Also, did you hit the lotto? You got a ton of extra money to be spend building two 4wd swapped cars? And a J series? You definitely need to spend more time searching regarding 4wd options. I have. And they're not good.
Anyway, on topic again. I'm still searching like crazy, but searching this particular site doesn't produce results like i'm used to finding. I'm not sure what i'm doing wrong? Most all the info i've found regarding the various swaps have come from that particular engine forum or from another civic forum as it relates to a CRX. As an admin here (are you the only one?), I know it's your job to tell me to "search" so I expected that. No worries. I have a LOT to look at for sure. And as you stated, the J 4wd (awd) set up seems like it needs more R&D. I went to those forums looking up info and think it's just lack of people actually trying to do it. Everyone has an opinion about why they think this or that but no facts or direct hands on knowledge to prove theories. If I can't find SOLID evidence that I will not be happy with the end result of doing a JAWD swap, then i'm going to strongly consider it. At least one wagon anyway.. Then K the other..
Now... Let me check this link you EASILY found that my noobness couldn't find. My bad
EDIT: Now see, the title of the thread is "2wd to awd swap". As an admin, are you able to search words with 3 letters or less? Because this site will not let me search anything less than 4 letters long. Other wise i would have searched exactly that. Instead, I searched "four wheel drive conversion" or anything I could think of that was 4 letters or more.
I had a J for a minute and spent weeks searching for a manual 4wd transmission that was rumored to be out there... with no luck. There's 2 running 4wd K's on our board, so there's definitely some good info available. I'm moving South for a couple of years, so I'm no longer considering much of anything.
Won't be easy. But nothing good in life is.
And thanks for not locking. I'll post up pics of my results if that's the route it ends up going. And if not, well then at least it has a link now! Thanks man
A good friend of mine that is an engineer is working on a J2K kit hopefully for next season. Not nearly as easy as some of the H2B or B2Ds that are out there. Hopefully if all goes well, it may be usable for 4wd K trannys too.
Exactly....
its from a its from a 2010 TL with the SH awd
here is a link to the site i hope to here about a awd J swap wagon
http://www.car-part.com/cgi-bin/search.cgi
