Oil in the wrong places!
                    doing some body work, and ran into this!
Another member recommended the o-ring. I checked it out, and it was not.
I believe I found the leak.
Does anybody know what that part is called? I think it maybe warped.
To make matters a little more frustrating, I was going to change my spark plugs when I found oil in there.
I had replaced the seals in may, with the o-ring as well.
I'm not sure if there is a gasket for the water neck. I'd have to check the service manual, but Hondabond would work there just fine.
It is called a water neck? I did not know that!
