Developed erratic idle when at operating temp with DPFI. (FITV vs IACV)
                    This is a repost from my build thread, but didnt get many comments so figured I would post here. Any advice, guidance, help would be appreciated!  Thanks!
http://www.civicwagon.com/showthread.php?14211-prennro-s-new-wagon&p=182593#post182593
So now have developed the dreaded irratic idle. Have experienced this and fixed this on my B-Series by cleaning and threading in the Fast Idle Thermo Valve (FITV) and/or cleaning the Idle Air Control Valve (IACV). Good trouble shooting and how-to write up here: http://www.superhonda.com/forum/f55/troubleshooting-idle-problems-259965/
Doesnt seem to have any vacuum leaks and I also made sure I bled the coolant system.
Anyway, pulled and cleaned the IACV. No change. Went to pull and clean the FITV and couldnt seem to located it! Im just wanting confirmation that my model (89 wagon DX, 2wd, D15B2, DPFI), doesnt have one and if it does (or the equivilant), WHERE IN THE HELL IS IT!?
I am assuming that with the all in one throttle body, intake plenum of the DPFI, there is an alternative sensor that may have gone bad, causing the idle issues when warm.
I am also assuming (minus the 13 hp gain) this may be one of the reasons people swap over to the MPFI, as those setups look alot more familiar to the B and D-series ive messed with.
What I pulled and thinking is the IACV is circled in red.
Attempted to pull the 2 sensors, one circled in orange and the other in green, but when they wouldnt easily pop out after removing the phillips heads holding the small metal plates, I left them alone.
Just something flat to block the air from going into the iacv valve.
UPDATE: Blocked off the iacv per nstice's suggestion above to find the iacv working. The combination of replacing the split tubing and plugging in the unplugged harness plug has seemed to fix my idle issues.
Thanks to all who offered suggestions!
