Shaking at stop and terrible gas mileage! HELP!
                    Okay I have been to a couple different "Honda specialist" and no one can tell me whats going on or try to even help me.
I the stock D15b2 and I havent done anything to it except added a cold air intake but it was having these problems before it. All I know is it shakes and the idle fluctuates sometimes when sitting at idle in every gear (automatic). Also im guessing this is making my other problem which is pretty bad gas mileage. Im getting about 25 mpg with my best being about 27 mpg and I dont drive fast or slam down on the gas.
So far I have checked the idle air control valve and injectors and they seem to be fine. I also replaced the fuel filter which was terrible. I had a mechanic do a valve adjustment which didnt seem to help at all even though they swore that was the problem. They did it while the engine was still pretty hot which I was told recently that your supposed to do it while its cold like really cold! Could that be the problem? maybe the adjustment didnt take because of the heat? Also the dumb mechanic told me that on these old Honda engines your supposed to hear the valves but before I couldnt and now after the adjustment I can but it seems like such a good small engine should be quiet (like it was before the adjustment).
I dont know what to do. Please help
I know my rear engine mount is going bad but the other two are new. Also I think there might be a very very small leak in the intake manifold gasket.
Oh also when you pull the wire off the number 3 plug there almost no change at all in the idle which is really weird to me. Because of that I had multiple compression checks done on all cylinders and everything was great (which makes it more confusing)
Any ideas are greatly appreciated!
definet vacume leek or a bad injector on # 3 switch 3 and 2 if it moves then thats the prob if not
spray carb cleaner around the intake gasket and all hoses or gaskets to intake if engine revs up or even dies there is your prob
As many honda's that I have worked on valve adjustment COLD, not say all but most as far as I know and I don't know everything. Like Jimmy427 says check that vacuum leak that could be a bigger problem that just a small leak!
Did it just start doing this or did it just apeared one day. Thing we need to know to help you. I hate to say this but its turn just because its new parts doesnt mean its good. (new puppys die to) as much as I hate to say
Does it do it all the time?
Does it smoke (sometimes all the time?)
Does it have a check engine light?
Are the RPM higher than normal at idle?
Compression checks hot cold with small amount of oil in the cyl or not?
When they pull the spark plugs did they look ok or did they have lots of oil, fuel, or oil deposite?
Did they do a leak down test on the cyl to check if its rings, valves, valve guides.
Any other noises that come about.
Check on these and let me know, I will help as much as I can. Any question just ask
The shaking and bad fuel economy is consistent (I replaced a broken pcv valve yesterday and it helped a little)
It doesn't smoke at all.
There is no check engine light, and there never has been.
It idles pretty high when warming up which is normal but then it drops to like 500 rpm once it's warm.
The compression checks have all been good and have been done by multiple mechanics, and there hasn't been any oil in the cylinder.
Because it's running rich for whatever reason there is some fuel deposit on the plugs but no oil.
I'm not sure if they did a leak down test but since all the compression tests were good I didn't think it needed on.
There are no weird sounds
The car over all runs great but the shaking and bad gas mileage is confusing.
I'm going to try to clean the throttle body, intake manifold and iac today
oh and my car never sputters or has a loss of power, thats why this problem is confusing too.
im gonna adjust the idle speed and see what happens
Yess!!! But idk at the same time because you said the CEL. But things like that all play a role. I had a similar problem, especially with the AC on, but my CEL came on going 75 when engine was warm. O2 sensor fixed that. My thought was it wasn't going into closed loop.
Also I got some carb cleaner and cleaned as much of the intake as i could and i did find a vacuum leak. There are two very small hoses coming off the back of the intake right next to the throttle. Hopefully someone knows what im talking about. One has a yellow stripe on it. Anyway the one with the yellow strip seems to have a vacuum leak judging by the fact that the engine bogged down when i sprayed on it. I dont know what that specific hose does though.
Anyway after a decent cleaning and some idle adjustment it does run better. After this tank ill see if my mileage gets better.
It still shakes a little but i figure after a little more cleaning, a rewire of the o2 sensor and the rear motor mount it should be almost gone.
To anyone that would know, Should I still do a cold valve adjustment? The slight clicking bothers me
This may sound stupid (or someone has mentioned it) but, it happened to me: Check all your ground wires! If they look bad, then they are bad. I couldn't pass Emissions because of a bad ground. We put my wagon on a Snap-on scope, and it makes a massive difference whether or not you got a closed loop.
Thanks everyone for your help!
hah lol.
