Rear Differential Mounts - Holes Tapped on 2wd Chassis?
                    The last time I was at the junkyard I was checking out a '90 AWD wagon, looking at the mounting points for the drivetrain etc. in case I decide to try to do a 2wd/4wd conversion in the future (my wagon is an '89 2wd.)
Anyway, looking at my wagon, I'm not seeing the threaded mounting locations for the upper diff mount nor any threaded holes for the driveshaft "protectors" etc. on the body. Obviously, I'm aware that the rear of the differential mounts to 4WD version rear crossmember, so that's not my concern.
For some reason - wishful thinking, mainly
 - I was expecting to see threads, unless I just missed them.
So, do you know off-hand if I should be seeing them? Interchangeability/interoperability of parts across different models always seems to make for a lively discussion...
Whatever happened to just tellin' a guy what he wants to hear? Sheesh!
