Oil pan gasket leak (auto. Rt)
Freek
                Wagonist
                    Is there any other way than besides removing the tranny to maybe pull this off. It leaks in the rear.
Freek
                Wagonist
If it is just the oil pan gasket you should not have to pull the tranny.
Just drop/remove the exhaust pipe from under the engine, drop the oil pan &
replace the oil pan gasket.
If it is the rear main seal leaking then you'll have to remove the tranny to get to it.
At least that has been my experience.
yeaaaahhhhh you're kind of effed then lol
You can either try to remove the transfer case (which I couldn't figure out how to do and aborted for fear of screwing something up), or pull the whole transmission. Most people say its easiest to remove the entire engine / trans together. Just for an oil pan. yeah it sucks. been there myself.
OP, i suggest you pull it all out, replace the oil pan gasket and the rear main seal since you will have access to it anyway. Not a bad time for a new clutch if ya need it.
