B18C1 Swap 89'2wd Wagon
So I found allot of inspiration to do a B18 swap in my 89’ 2wd wagon here on HCW. This is my first swap so I’m reaching out while doing as much reading as possible. I purchased a B18C1 out of a 96’GSR with 5 speed LSD Y80 Trans. I have the original harness and computer with it. I have been doing research and wanted to know if anyone with experience would offer any advice on the swap as a whole. It will be naturally aspired and a daily driver so I want to make it as dependable as possible.
All comments are appreciated.
My plans are to
-Retain The AC unit. I read that I have to buy a bracket to do this but I’m doing more research. (I have not looked into converting to R34A from my current R12 refrigerant).
- I know I will need to convert to OBD 2.
- I already have the mounts so bolting it up should be a problem.
- I will need to notch the frame to clear the Alternator.
-I would like to use the original GSR cluster from the donor Teg.
-I have to look into axles.
-I need to figure out a Cable to hydro conversion
-Planning on having exhaust system built once its complete. (I do have a DC header for it tho)
- Drink lots of beer in the process.
Other plans include
- 10.3 brake upgrade
-15/16 MC
-Alt and Dual battery/electrical upgrade
-Air suspension (Yeah buddy!)
-Some new meats and some not to fancy wheels.
-Traction bars(maybe)
My plans are to
Other plans include
-15/16 MC
Biggest this is to read around not just on this forum but others as well. Pretty much all the 88-91 civics are the same. So they are interchangeable.
Cool. Ry-wire is a great resource thanks for that... I'll be calling them next week for info.
The mounts I got are specific for the b series with hydro from Innovative so they should mount up.. so unless there is more to it I think I'm good there. They offer a cable to hydro kit as well so ill see what that's all about. got the AC bracket on the list, I am however uncertain if i should use my stock AC compressor. Great input thanks!
http://www.youtube.com/watch?v=DBtOXjVOf2w
My AC still runs nice so guess it makes sense to keep it if it will fit.I hear R134 is not as efficient in a system that was designed to run R12. Again one more thing for me to research on.. thanks for the heads up.!
Hush22 seems like the way to go. Copy that on the P28. I'm on the hunt...Looks like Ry-Wire offers one for under $200.
The Hush kit in a nice piece, but if you need to stick to a budget you may want to look at other kits. http://phearable.net/ is also a great company for ECU tuning and chipping services. They have done a few for me in the past.
I need email the guy about the hush 22 for more info but do you know what he charges for the two different kits?
This is the one I use its better made then rywire and I'm telling you this cause I own both jumpers
http://www.ebay.com/itm/OBD0-OBD1-HONDA ... 0614329761
Pm me if you have questions I'll be happy to answer them
Right on! I definitely appreciate the info. Ry-Wire is expensive so I'm defiantly up for suggestions. Ry-wire stuff looks like its really well made what differences are you seeing in the two? I'm wondering if i can buy all the plugs and make my own harness....of course I would need a schematic.
Notice your mom don't have to glue this jumper to keep the pins from breaking
i'd like to see proof of what you had to fix. And dont tell me you did not take photos, because i know his stuff is expensive, and comes with a reputation, but there is a reason for it. spend that kind of money on some wires you're most likely going to photograph the problem you had and tell others. Did you contact him and tell him what happened with your part? Or did you just decide to fix it your own way and be done with it?
I run Rywire jumper on my its great but the pins do break and not a big deal I know how to fix them I just cut pi out of an old ecu and replace it
Also I see tid bits about loosing the Vtec Pressure switch. What is the intended purpose/theory there?
Also note OBD2 engines will have a knock sensor that will be deleted with the OBD1 ecu.
If you're not afraid of a soldering iron it's defiantly worth it. I'd rather spend an hour soldering than spend $100-200. As for soldering obd1 plugs to harness, I'd rather have a way to go back to obd0 if I needed. And I'd much rather do the soldering sitting at a desk/workbench than trying to do it in the floorboard of the car.
When your on a tight budget time is easier to spend than money.
The B18 Harness from Ry-Wire does not come with the vtech connection and they give you an option of paying $5 for the Plug. I'm using a USDM B18C1. I'm a noob here so again thanks for all the help. Its all very intriguing. Question is, why not monitor your Oil pressure and continue the use of the pressure sensor? I assume that without the pressure sensor vtec will still engage regardless of your oil pressure or rather IF you have sufficient Pressure.. If that's the case wont you have issues with positive engagement at the specific RPM with low oil pressure. Thats good info. Notes are piling up.
I'll have the engine this week. It has 140K and I'm thinking I will go through it and rebuild along with the LSD trans..
Anyone rebuild an LSD on their own? I'm thinking about doing it myself for half the price if I send it out. $600 VS $1200. And I might even get some tools out of it. Looks like another interesting thread will come out of it.lol
I cant wait myself!, mine is the slow build.. plus I feel like I wanna ring out all the mileage I can out of this 1.5..lol. I just rolled 200K so we'll see. I just recently got back to putting this swap together. I have been distracted with a diesel Project, school, work and such. With all the new 2013 smog crap here in CA, I have been rethinking my build, so the delay is probably a good thing. I Plan on having it Bard so NA is going to be my best option unless someone can convince me otherwise. Innovative mounts makes a good shift linkage and all the mounts you will need. I havnt gotten to the axles yet so that is still in the planning stage. I might have some lights just PM me. I don't believe I have a hatch cover tho...
I swapped in a B18a1 into my 91 wagon. Wanna keep my A/C from t. what the previous D16. What bracket do I need to make fit and work? I heard I need on from a Del Sol??? Please assist and confirm
thx u!!!
