Steering rack issue
Freek
                Wagonist
                    Below is my problem. I don't have a welder close by but I have a rt rack I could change out are there any differences ?
Freek
                Wagonist
As far as I know, the only 2 different ones are for power or non-power steering.
Remove front wheels.
Disconnect both outer tie rod ends.
If the car has power steering, disconnect the lines. There's a sheetmetal cover on the bottom you'll need to remove for access.
In the driver's footwell, disconnect the steering shaft u-joint from the rack's input/pinion shaft.
Remove the rear engine mount and bracket.
Put a floor jack under the center of the crossmember to support it, then remove the four M12 (17mm head) bolts that secure it to the unibody.
Lower away!
Pics in my Fool'sGold thread of that.
