B-Swap Mount doesn't fit B20: resolved
                    So in the picture below is the stock B18 mount on the left and the B20 bolted on the motor to the right with the B swap mount attached.  I cannot put the B18 mount that connects to the motor on the B20 as it is sized differently and has a different bolt pattern.  My B swap mount (on the B20 in this picture) is fits the B18 but not the B20.  I have 2 issues I can see here: The B20 has the 2 bolts that connect to the B swap mount in different locations (causes the mount to be crooked) and it is way shorter than the B18 motor mount. I'm getting ready to drop the motor tomorrow and I was shocked as these mounts are supposed to be universal for the B-series.
To alleviate the issue you can see in the stellar depiction below, (chassis mount is short of B20 motor mount and the bolt pattern is off) I was thinking I could put a plate under the mount that connects to the B20 engine to extend it out and drill out the mount that connects to the chassis to straighten it or I could make an extension plate with 4 holes in it to connect the chassis mount to the stock B20 mount. I don't want to waste money on another "B to EF" mount that won't fit the B20.
