No spark!!
                    So heres the situation.  On my 91 RT the clutch recently went out.  To replace it I was forced to remove the whole engine/transmission assembly.  When everything was out I removed all a/c related things in the engine bay.  Now that I have everything back in place the engine wont start.  I came to the conclusion that there is no spark but there is power going into the dizzy.  Just none coming out.  Is there a crank sensor that I could have overlooked possibly?  Or a ground to the dizzy?  I know that the dizzy itself is not the issue, because I put another one on and same thing.
1. Speedo does not work. I am 90% sure I installed it correctly however I think I pulled on the chassis end of it. Where does it connect to?
2. CEL comes on randomly. Is the double pin connector to cross in the same spot as all obd 1 hondas?
2- Possibly the light is coming on because there is no speed signal, fix the speedo and the light should go away.
I have done a write up on testing distributors with lots of pics
