CEL 1,4,10
                    Well it threw a CEL today, doing 75 it bogged down a little, pushed in the clutch and glided about 1/8 mile then applied minimal throttle for the last 1/8 till i pulled over. opened the hood, it was idling smooth but had a different sound toward the driver side part of the eng. Checked codes and got #1 O2 sensor, #4 crank sensor, #10 intake air temp. shut the car down, started it back up ran just fine. no noticeable power loss. it was between -4 and -8 deg out.
Got home and started doing some research and come to the conclusion that my dizzy is done for, most likely the bearing failed. This forum has said that it could make the timing jump, my concern is i have bent valves due to the timing jumping, could this be, but with no loss of power? i plan on doing a compression test on it to verify. just worrisome due to being 300 miles from home and no garage to put the car in to fix while i'm on vacation for the next week.
all help and experience is appreciated!
bowz
bowz
I will agree that if you have any doubt about the condition or age of your distributor it's a good idea to replace it- especially if your walk home is 300 miles and 8 below zero!
edit: On thinking back a little, my wagon had a similar problem. I'd get a check engine light, sometimes with power loss sometimes not. Code was always o2 sensor. Distributor ended up fixing it.
88loganm, yes when I'm above 3k my tach will flutter every few seconds, was doing that before I threw the CEL. As for the long trip, I make a 600mile round trip almost every weekend, but then I'm only going 60-65. I've put around 12k on it in the past 6months comuting from my job back home every weekend I have off.
Bowz
As the plan for today is, I'm going to check compression in each cyl. Not sure what it should be, I'll look it up in the Honda manual. Put the new dizzy, cap, and rotor on.
Thinking out loud. If they are all low, then it would mean that the rings are bad, and/or valve seats are bad. When I did the top end they only regrinded a few seats. Would hope they would still be good. I also read on here that the spread between cylinders should be less than 28psi?
Thanks again guys for the words of wisdom!!!
Bowz
eng running
http://youtu.be/Fo9tdWVoDns
bad bearing
http://youtu.be/tCAddRowW0k
any more input?
bowz
Bowz
http://www.tegger.com/hondafaq/faq.html#startrun
well tonight I put in the new dizzy, so far so good, goign to carry the old one for a just incase.
http://youtu.be/2qQpP9pHpbA
Took it out for a test drive before i timed it, here is a little vid. (correction it was -10 out when i installed it outside.)
http://youtu.be/IFaCCJm1mx0
thanks guys!
bowz
bowz
