Clutch Cable loosened itself up ?
                    Yesterday i stoped at the gas station.. No problems in the way in, came out, went to take off and my clutch pedal went right to the floor and the clutch would not dissingage.. I expected to find a broken cable when i looked at it today.. But the cable does not seem to be broken.. I tightened up the plastic adjusting nut till it was pretty good and tight and that got the clutch back.. then i took it for a little ride came back and checked it and the plastic adjusting nut would turn again.. Is there something that is saposed to keep that nut from loosening up ?
One more question.. If i get a new cable for it, how does the pedal end attach to the pedal? It appears the pedal assembly has been welded in from the previous owner already. So im not sure if the pedal will come off or not.. Hoping it doesent need to to to attach the new cable.. Thanks for any advice.
Just another option
Forgot to add, you need to check your pedal assembly, it's really common and it's free to check.
It should be right under the nut. Has a rubber nub that prevents the nut from rotating. Can you tell if it is loosening up? Take a paint pen and mark the nut/threads.
Agreed. Sounds like what happened to me when i thought my clutch was bad. I dropped my trans three times in one day just to find out that the pedal assembly was broken.
I have 91 EX 4 door pedals in my wagon (so i could have cruise control switches). It bolted in but I had to "clearance" the AC duct or the clutch pedal would hit. A little heat and pushing in the right place solved the problem.
Fine tuning the adjustment can involve preference, OK so long as
1) the release bearing isn't touching
2) the clutch can be fully disengaged
