Head gasket question
                    I am changing out my leaking head gasket. It looks like it is just leaking on the outside of the head (no overheating, smoking or dirty oil). I decided to go with a d16y8 gasket because of the material and compression bump. The question I have is: What head bolts should I get? There seems to be two different kinds of bolts (according to a d15b2 service bulletin), ones for leaking gaskets and ones for non-leaking gaskets. I figured I need the ones that are for the leaking gasket, duh. The thing is, since i'm using a y8 head gasket (which is an mls gasket) should I use the new bolts and torque specs?
Jay
