92 SOHC ZC into 88 RT
                    I know it will drop right in and bolt up.  But I'm worried about wiring/ecu.
Do I need the ecu because the 92 is OBD1 and my wagon is OBD0? Can I use my current harness and ecu? I'm not sure the differences between the OBD0 and OBD1 ZC's. I searched here and d-series.org but kind of came up dry.
Thanks for any help you can give me.
getting a new motor .....
i say to b safe get the harness&ecu if they r cheep.....
then look thru the off the wall swaps bam has done im sure u will see exactly how to combine or repin the obd0 and obd1 harness so it all works
1) use the OBD0 injectors
2) repin the harness for the OBD1 distributor, or use your old distributor
3) extend or relocate fan switch plug on harness to reach thermostat housing
4) use the 1-wire oxygen sensor
You'll need the ECU and the harness (only for plugs and stuff), and an OBD1 jumper (unless you're a wiring guru and hardwire the OBD1 plugs onto your car harness underdash)
1) switch the OBD1 injector plugs onto your harness and delete the resistor box.
2) repin the harness for OBD1 distributor
4) change the ECU, then run the 4 wires for the OBD1 oxygen sensor from the ECU out to the sensor
I think that's all. OBD0 is cheaper and easier.
