MT RT4WD Wheels spinning in neutral.
                    So I just finished rebuilding my engine and got it in the engine bay and started it up for first time last night.  Low and behold it actually started (Wooohooo) but anyways there was a slight problem.  When I let out the clutch with the gear selector in neutral the left front axle was spinning.  Luckily I had the car in 2WD and the front end off the ground so we didn't have a disaster.
I think I might know what is causing it but I want some ideas before I dig around too much. When I pulled the shift cables off the transmission to remove the engine the cotter pin broke off in the upper (larger) shifter arm. I was able to grind the pin off enough to get the cable off then I removed the arm and drilled out the pin before reassembling. Moving quickly I didn't think to make a mark to index the arm before taking it off so it was a bit of a guess putting it back on. If that arm was off a tooth could it be causing this problem? Is there a way to line it up other than trial and error. With the way the bolt goes across the back I was thinking I couldn't get it wrong but maybe if I was off only one tooth either way it would still go through. I did move those shifter arms around during this process as well, could that have screwed it up?
Its normal to have the axles/spindles moving while the car is running in neutral suspended in the air.
