ecu question
                    Im will be running a d15b7 block with a d16z6 head,
what ecu should i be using? its gonna be a daily, possibly with small boost later on down the road.
build thread coming sooooon!!!
you can use P28 (stock d16z6 ECU), or you can modify P06 (stock D15B7 ECU).
more easy is to use P28. but that one will be more expensive.
I agree go with a p28
