timing belt
ok i have done some reading and i have done this job a few times but i cant seem to get the motor to drop down on my wago i do have the rtawd but i still dont see it being anymore of an problem the motor settled about an inch and wont drop anymore. do you guy just go for it with that are is there something i am missing i need to get this done so i can check my compression. i hope the for the best.
any insight will be great.
No need to lower the engine. Pull the crank pulley off then place jack under oilpan. Pull driver side motor mount. Then proceed to pull the covers and timing belt.
not too sure what you are trying to do, but a timing belt replacement has nothing to do with lowering the engine.
