Dpfi to Mpfi HELP!!!
                    So I'm doing my Multi port swap and I'm on the part of wiring the wires to the ecu. Well it says to move pins c1 and c2 to b10 and b12. But on my b harness plug 12 has a white/red wire pined to it and b9 and b10 an the ones that are open. So my question is WTF do I do!!
And I tried searching it already.
TIA!
TIA!
Use the standard harness and run c1 and c2 to the dizzy. c1 goes to the blue/green wire on the dizzy and c2 goes to the blue/yellow wire on the dizzy.
a3 and a7 go out to the engine bay. a3 goes to injector #2(red wire) and a7 goes to injector #4(yellow wire).
It has been covered, I helped another member on his build thread with this awhile ago.
HCW is where i got my info for the dpfi to mpfi swap.
b9 should be open and b10 should be orange for the crank angle sensor
At least that's what this chart says
Good luck hope this helps
Connector B
Pin B12 is not open as you can see.
If anyone can help it would be most appreciated.
^^ correct^^. Sometimes you'll find a wire at B12, just disregard it, or use the pin. It's unused on the dpfi.
The easiest way is to depin C1 and move it to B 10, depin C2 and move it to B12, Then add pins/wires back to C1&C2 for the Cyl Position sensor.
Add the 2 injector wires and you're good.
hondaswap.com has been a huge help to me, there are several different swap how-tos stickied there.
But thanks for all the help, you guys are really a big help. Hopefully my y8 mini me will be done tomorrow. Then my wagon is one step closer to wagon of the month
Question answered. Please lock.
