A few questions
                    Ok gentlemen, I have a few problems with my car and really no idea what the cause of them is.
First, when i turn the steering wheel to the right, it makes a high pitched humming sound that is coming from the front right. Only happens when the wheels get passed the middle.
Second, when the car is not warmed up yet, i give it gas, and it sputters off the line, sometimes stalling. When the car is warmed up however, this is not an issue.
Any thoughts on what these problems could be? Thanks.
just check everything out. alignment,how tire is wearing,fuid and belt if you have power steering.
remove the wheel where you think the noise maybe.
start illiminating them.
Or it could be a vacuum leak somewhere.
Mine does the same thing sometimes. When cold and I press the gas it'll die but when it's warm it doesn't do it.
Also to note, my buddy had the same issue with his Prelude before he fix/sold it this week for a Mazda Protege i believe. Told me it would sit for a bit or all day and the issue would come back or cause a sudden surge to it dying out or just acting funny when it was running/turning on... Check it out, might help or not, but wouldn't hurt to try. Best of luck!
