Engine misses, pops and backfires, loss of power
                    The other day I was backing out of a parking space when my wagon just died on me. Started it back up and it was running really rough, missing horribly. Died again, then wouldn't start..  Long story short... Had to replace the distributor due to the bearing being seized. Put in the new distributor, finally got the car running and it still sounded horrible. Missing really bad, popping and backfiring. drove it home (less than a mile from where it died). It was smoking, couldn't tell where the smoke was coming from though. It's hard to explain exactly what it sounds like.. It doesn't knock, just some ticking from the valves. Nothing was done with the timing, everything was taken apart and put back together in the same locations and positions as removed.
Going to do a compression test in the morning to see if my assumptions are correct. Could it be possible that there is a hole in one of my pistons causing it to backfire and pop like it was? Possible broken valves?
Any help would be appreciated...
I'll try and get a short video of it, if possible.
Check timing. With #1 cylinder at TDC, are intake and exhaust valves both shut? Crank and cam marks lined up?
Lucky for me with the timing jumping a few teeth, no major damage, just idiocracy on my part.
Thanks for the help guys!
