Advise needed... '88 Rt4wd no start
                    Evening guys! So, I thought I would finally chime in and let you guys know what my problems are...
I recently bought the car, 1988 rt4wd, the previous owner was the original owners son. The father was a mechanic and rebuilt the motor top to bottom, and i believe it because everything i take apart looks new. Engine has less than 40k on it, the car has 260k. I don't have a compression gauge at the moment, but will be borrowing/buying one this week.
Back in 2010 he was having clutch problems and stopped driving the car, and it sat until the day i picked it up. It was running great back then, but it won't start now. Which brings me to today...
I am getting fuel through the rail and plenty of spark at each plug, but it just cranks and cranks... Injectors not pulsing? I pulled the plugs and they are all tan, but don't smell or fuel. Fuel pump is good, gas still ignites (I poured some out and lit it on fire, thus concluding my test) I'm going to go check for voltage at the injectors now that the battery has charged, any other ideas?
Thanks in advance fellas!
Injectors blocked?
Next time just edit your post.
My bad! I didn't know I could edit the title... Thanks
Resistor pack? Is that the silver box behind the driver's side shock tower? Has cooling fins? I'll check it...
I pulled out the rail and injectors and everything seems spotless, however I don't know how to check injectors, and new ones are $50 each. Could all 4 be blocked? The motor doesnt even kick while I'm cranking, just keeps making rotations. I'm also going to completely drain the tank since I just noticed there is a convenient plug underneath
Thanks for the replies fella, keeps me motivated!
I'll run to the store and pick some up, at this point if it at least kicks I'll be happy...
You can turn the engine over with the injectors stuck in the fuel rail but out of the intake to see if they are spraying
Pull back the passenger footwell carpet and see if there are any flash codes.
Check base timing and firing order- 1-3-4-2 clockwise from bottom left when looking at the distributor end-on.
viewtopic.php?f=5&t=14034&p=161740#p161740
Thanks again guys!
B)Since the motor was rebuilt.Go into the engine bay & recheck all the electrical connectors .Could be when they put the eng. back 1 or more connectors are NOT making good contacts so your sensors are not recieving or sending good signals.
C)It could be your ignitor:
Iginition upgrade
and read the following:
How to test/rebuild dizzy & alt
D)Otherwise try swapping another Si ECU in.
Pulled the carpet back and no CEL code
Checked all plugs, everything was hooked up but I unplugged the majority and checked them all, everything looks nice, no corrosion.
I am getting great spark across the board, all it was running perfect so I'm sure the wires aren't out of order, checked them anyway and all good
Timing belt is good, appears newer, minor slack
I'm stumped. Really leaning toward another resistor box, gunna grab one tomorrow at the pnp and hope that fixes her. If it does I may be going obd1 injectors/bypass the box.
Any other thought guys! Thanks -ricky
as always, thanks in advance! -Ricky
So, as a treat to myself, I installed my tokico blues, eibach adjustables, and skunk2 rear LCA's (i was told they are s2's). needless to say, I am very happy! Also got my free cracked broadway mirror installed, tomorrow on goes my volvo lip, possibly my front tow hook, i haven't decided if i like it or not... and either my era correct yellow '80s Hella fogs, or some lights i took off my quad that i think would look great in the front bumper. I'll put up some pics first of both mocked up, get your opinions. watching SOA and crashing out now. thanks for all your help guys! -Ricky
I blew the passenger rear brake line earlier too, lol. The car is fun to drive, needless to tell you guys.
