Adjusting hood release
Evening folks...
I replaced the broken passenger-side hood hinge on my car today, thinking this would solve my hood release problem... no such luck.
I need an assistant to press on the hood (where the emblem is) for it to release when I pull the lever inside the car.
How do I adjust the mechanism under the hood so my hood will release?
Thx !!
Thx !!
i know this won't help, but i've got the same symptoms. Do you have a manual to look up the way to tighten/shorten the cable release itself?
I've tried adjusting the latch backwards but it doesn't help...
I'm going to try adjusting forwards to see what that does.
http://www.honda-tech.com/zerothread?id=1628750
http://www.honda-tech.com/zerothread?id=1033566
