What do you get miles per tank
on AVERAGE i get only 250.. highway or city. 250 no matter what. its probably because im cruising at 80 mph.
anyways what do you get miles per tank?
i'm usually on highway, cruising at 70mph
The catch is this is a '90 2wd 5spd, the trans being from an HF crx. I'm not sure if consumption is adversely affected by "lugging" the engine. In 5th @ 60mph tach shows <2000 rpm. I can comfortably cruise in 3rd on highway.
What size is the tank? 5.4 gallons filled it back up. All these miles were off-highway, 16 mile commute to work.
when ever i fill up i put in about 10 gallons and go a little over 300.
how?! i only get 250? do u drive normal
Why?
Higher compression ratio than stock? Forced Induction? Really advanced timing?
Hi, go see this web site: http://www.gassavers.org/
A lot of info on fuel economy.
With my summer tire just installed, I should hit the 450 miles marks with the wagon. Btw, my rpm is at 3000 rpm @ 60mph. With your HF transmission, you should have better mileage than me, since you are running below 2k rpm @ 60 mph.
Anything over 9:1 compression really should run on the higher octance petrol..
I beg to differ...although it might stem from the RON vs MON way of calculating octane.
Besides, isn't the wagon around 9:1? (USDM...no ZCs)
My original point being that 87 was recommended by the manufacturer.
*Using a higher octane is a waste of money unless you need the additional resistance to detonation.*
I belive your 91 is around the same as our 95/6 octane here.
I understand the minimum available in Japan is 95/6 RON and therefore their ECUs are tuned for it.
So i guess really its not the compression that matters too much its the ECU that you run?
Now with the Y8 mini-me we get 32-35mpg. Worth the swap right there (especially since I did it due to a timing belt snap, and the old head "may" have been toast anyhow). Easy 33mpg average.
It gets mid-grade octane. (Y8/A6 mini-me is in the neighborhood of 10.3:1 8) ). and the block has 201,000mi (~90kmi on the Y8)
I actualy got the best tank yet while the wife was out of town (it's her car mostly), and I was NOT driving it gently - - about 1/2 the tank was used rallying up and over Berthoud Pass on the way snowbaording (up to 12,000ft from the 5,500ft my house is at). that was a 35mpg tank!!
New clutch is in now, and all new ball joints go in tonight (then alignment). She'll drive like a dream soon.
-Chad
i averaged 41 mpg cruising between 70-80 mph on an up and down hilly interstate. i was pretty impressed
lol 250 makes me wana get another car
OK, displaying my ignorance here: WTF is a mini-me? Sounds like a head swap? 2nd tank I got 29 mpg, included a 120mi. highway trip to a road century Saturday with a couple work commutes. Will the MPFI conversion help with mileage? Really want to keep it simple, and not concerned with power/speed. This thing AIN'T fun to drive with the HF in it.
Just a point of clarification...its any non-vtec d-series block with a vtec head. Not specifically a 1.5. If you can stay off the vtec lobe, it will get 40+ mpg easy.
Yes.PLUS power.Your $$$ might be better spent on a front spoiler/side skirts and or a bellypan for increase mpg.
13s.The CRX HF are very lite plus looks really good without the center cap.Another good choice are the '92-'95 VX whls.
Did you put in the HF flywhl too :?:
on topic, I don't know how many miles I get per tank, I never let it get that low... but I've been getting high 30's in gas mileage. I'm pretty sure that I can break into mid 40's if I keep the speed around 55-60 mph.
EDIT: I have a mpfi swap and get 36/39.
umm... no. What's an HF flywheel? Heavier? I really didn't start out looking for the HF, just bought it for $80 from a guy who had swapped Integra stuff into his crx. I may put the original trans back in ( needs input shaft bearing at least)
you're assuming there was a decision or logic behind the name but it was a stupid pop culture joke that just stuck ...the first mini-mes were happening at the same time the first Austin Powers movie came out. And coincidentally the LS-Vtec concept was just gaining popularity.
So you had the larger, initially more popular LS/Vtec and than the smaller, almost absurd D-series attempt...mini-me was
It has nothing to do with the displacement, just that its a "small" artificially created D-series frankenstein type of setup.
