ZC vs. Si Tranny
                    Which is better?
I'd like to come out of the hole better, but still have a good top speed.
I heard that the ZC is geared lower, but I don't know how the Si is geared.
I'm going to be doing a auto-to-manual to manual swap, and probably going to get a ZC as well. Let me know your input, Thanks!
This is a common misunderstanding...actually, when comparing stock to stock, they are within 500 rpms of each other in 5th gear.
I think davens' quote is from an autoshop. So when they say 'we' they mean the people who work there i guess.
We is Effin Motoroworks.
Comprised of myself, Kwicko, Reuben and Johnny.
A little hobby business we had going for awhile...it could have took off, but none of us was willing to commit the kind of time/resources it takes to run a business, so it is effectively shutdown.
Helpful friendly tip: Next time you want to know where something online comes from, just paste the title, or even a couple sentences into Google. It will find it. Its how learning institutions are starting to check for plagiarism (lazy students beware)
practically, no.
http://www.gear-speed.com/ sells hybrids
Not true...a stock ZC performs VERY similar to a stock Si tranny.
And even when you pair the aggressive Si final drive with the ZC 1-5 gears, its an awesome transmission around town...but it buzzes a little high on the freeway though.
so for an autoX machine, the ZC 1-5 and Si final drive would be a good combo?
[analogy]
Picture a 3 speed bicycle.
One gear at the pedal crank and three gears at the rear wheel.
The one gear is the final drive...the three gears are the 1-5 gear set.
A Si bicycle has a very small(fast) pedal crank but very large(slow) gears on the rear wheel
A ZC bicycle has a very large(slow) pedal crank but very small(fast) gears on the rear wheel.
[/analogy]
Which is better? Neither, really. If I had to pick: ZC...because if gives you equal length axles(but additional expense) and a beefier differential (better for high rpm clutch drops).
While the 1-5 ZC gearset is a little more even spaced, its still paired to a dog final drive.
The Si gets a great final drive, but its paired to the just-okay 1-5 that you also find in a DX.
The best all around hybrid tranny is a ZC 1-4, Si 5th and Si final drive. If you use the ZC 5th, it's a little buzzy on the freeway (about 600 rpms higher than a Si).
Check your class for autoxing...it might bump you out of your desired class.
zc 1-4 Si 5th
Si 4.25 FD
guy I know has this one in his ride, nice tight setup
btw, is there any relation to Effin Vodka :roll:
Theres a picture i want to post up but then i'd have to ban myself.
