Are 88-89 headlights the same as 90-91?
As the title says, are they the same?
If not, can I change the mounting brackets with my stock ones?
crx/civic headlights will work as well. corner lights different, that's it.
i've done it, like last week- its pretty easy- like 4 or 5 screws/bolts..
Or you could try holding a heat gun to the headlight for awhile until you can pry the glass off. I'm pretty sure it's just a few small clips and a lot of glue/sealer holding it on.
just an idea.
Yup, that's all there is, sealer and a few clips. However, what do you use to seal the headlights again after you've swapped the glass ??
I can pull the bumper off around 30 minutes. (I've had plenty of practice)
save the 20$ and get the 88-89 and swap the housing out,
im cheap as hell, anything for an extra buck..
and you know what, the housing i swapped out were from those
projector lights-
my friend had 88-89 stock lights and i had the 90-91 projectors,
swapped the housing out with ease...
you'll figure it out...
