Carbon Fiber LIps?
If you can put CRX/Accord/DA Integra LIPS on the Wagons, why hasnt anyone put a CF lip from those model cars onto their wagons yet? I know there not direct fitment but from i read, you only have to trim a lil here and there depending on model vehicle lip...Just curious...
its not really a "little" you trim off. with the accord lip i installed, i ended up cutting like two inches off the ends. but with that hard-plastic material it was easy to sand down to make it look like it hadn't been cut. but with CF, im not sure how clean the cut would look, and how much it would take to make it look decent. would you really want to mess up CF like that?
good luck with it
fitment wise.....i guess the crx/civic si lip as ragenasian mentioned
but like duckie i had to cut off 2 inces on the end, and an inch out of the middle... it actually turned out really clean looking, but took forever...
plus i got the acura lip for free at the junk yard so it was good just
to cut up and mess with anyway...
post up pics! the legend is a new lip. usually its just the '89 teg, 94-95 accord, civic/crx si, and some mention of a VW lip (maybe the old jetta, not sure)
the wagons getting dropped,
plus i might put on a rear lip- its to be decided...
also got a little JDM tow hook on the rear...
pics by monday for sure...
yea..i got mine for $14 dollars...you gotta take 1-2 inches off the sides.
