Front and rear wiper sizes?
Can someone please tell me what size wiper blades should be used on a 1990 Wagon. Also looking for the correct size for the rear arm blade.
Brand recommendations would be appreciated too.
Thanks in advance.
    Fronts are 19", and rears are 16" iirc
    I get Bosch ones, last a year no probs 8)
  • ls_wago89ls_wago89 Band Wagon
    i found the fronts one is 19 and one is 20
    All the specs call for a 20" on the left (US driver) side, a 19" on the right, and a 16" on the rear.
    I use an 18" blade on the right front. The 19", if not parked way high for my liking, will hit the windshield molding at the bottom of its stroke. That wears the wiper linkage and transmission prematurely, besides being annoyingly noisy. It's the little things :P
    so: 20, 18, 16.
    I actually just put 19/20 rainx wipers on my car and I have no problems with the length.
  • I have the same problem with the blades hitting at that length but I am sure there is some play in my arms causing this problem. Had it on one wagon and not on the other.
  • i also am using the 20 drivers and 18 passengers cause of the rubbing at the bottom of the stroke and a 16 in the rear
    I'm using Michelin 17" in the rear.I've been looking at the pass. side & think a 20" will fit.
